C123 engine overhaul max HP
Tom
03-08-2004 17:49:00
I am considering overhauling the C123 engine in a 140. Is there a way to increase the HP? any suggestions or comments welcome. I'd like to get 30 HP out of the tractor. TIA, Tom
Red Rider
03-08-2004 20:12:29
 Re: C123 engine overhaul max HP in reply to Tom, 03-08-2004 17:49:00
Tom, you can get an 3 1/4 overbore kit that will boost your CU to 134. You can also take a little off the head and the block to increase your compression. The C135 engine stock produced 37 hp in 404 Farmall.
Stan(VA).
03-09-2004 05:41:20
 Re: Re: C123 engine overhaul max HP in reply to Red Rider, 03-08-2004 20:12:29
Actually he can't if it's an original 140 block. They came from the factory as the equivalent of a C113 block with the 3" to 3 1/8" overbore kit already installed to make it a C123. Without doing custom machine work (and then finding custom parts) the best you can do is either get or save a set of firecrater pistons and use a new set of rings. The aftermarket TISCO pistons have a shorter piston and therefore a lower compression ratio. The good news is that you're not to far from your mark, look at 240 Utility HP numbers. Basically the same motor turning a little higher RPM (2000).
Stan(VA).
SAmin NS
03-09-2004 11:52:38
 Re: Re: Re: C123 engine overhaul max HP in reply to Stan(VA)., 03-09-2004 05:41:20
I think you'll find that he can put in thinner sleeves to give a 3 1/4" bore. During the production of the Super A they started fitting the C-123 block (as in the Super C) around 1951 or 1952. They kept the bore at 3" by using very thick sleeves which my 1953 Super A has. So far as I know these blocks and all those following SA-1, 100, 130, and 140 can all be taken out to 3 1/4" with thinner sleeves. Hope this helps. SAm in NS
Stan(VA).
03-09-2004 13:10:36
 Re: Re: Re: Re: C123 engine overhaul max HP in reply to SAmin NS, 03-09-2004 11:52:38
Sam, that's an understandable assumption that I also had years ago. Just doesn't happen to be true ;) Check the archives, I know I've covered this several times. The early C123 blocks (late Super A, Super A-1, 100, Super C, 200) are as you state (they fit the 3 7/16" lower sleeve OD), the x30 and x40 series are not (back to 3 5/16").
Stan(VA).
Brown Dirt Cowboy
03-09-2004 09:17:20
Stan(VA) I have a 1945 B that I oversized, had the bottom of the block drilled for the 3 1/4" sleeves had the head shaved and reworked and turned the governor up to 2000 RPM's put it on dyno turning 33HP at PTO have been pulling this tractor for 7 years with no problems at all. Tom
Stan(VA).
03-09-2004 13:00:04
 Re: Re: Re: Re: C123 engine overhaul max HP in reply to Brown Dirt Cowboy, 03-09-2004 09:17:20
Yes, Tom. I've done a few also. My point was just to say it isn't as easy as buying the 3 1/4" sleeve set and popping them in. On the early C123 blocks, that can be done easily as an in-chassis overhaul. All the others have to come out and go to the machine shop, then you need to come up with a solution for the O-rings.
Stan(VA).
Brown Dirt Cowboy
03-09-2004 17:50:14
 Re: Re: Re: Re: Re: C123 engine overhaul max HP in reply to Stan(VA)., 03-09-2004 13:00:04
Stan I don't know what was used around the bottom of sleeves as they were installed by machine shop when I picked the block up. Have never had a problem with leakage. Good strong engine now. Tom
Stan(VA).
03-09-2004 18:37:20
 Re: Re: Re: Re: Re: Re: C123 engine overhaul max H in reply to Brown Dirt Cowboy, 03-09-2004 17:50:14
All the automotive machine shops I talked to don't have the ability to increase the depth of the O-ring grove (the boring machine can't change diameter once down inside a bore), so you either try to sand down the thickness of the O-ring or spec out a new size which is what I do. Your B sounds like a nice tractor!
Stan(VA).
