Engine # vs. Serial #
Brett
03-08-2004 19:45:33
My 1944 H has had a missing serial number plate since I have owned her. I originally thought that the engine number was the same as the serial number but now I am told differently. Is there any way to figure out what a tractor's real serial number was if the plate is gone? Would Case-IH have any archival info that they could trace by engine #?
Farmallkid
03-09-2004 12:15:48
 Re: Engine # vs. Serial # in reply to Brett, 03-08-2004 19:45:33
52 is my M, the H is a 51. The ones on my M dont match. Engines a 51 and the rest is 52.
Farmallkid
03-09-2004 12:14:13
The numbers on my brothers H match up, its a 52
jed
03-09-2004 05:41:32
How do you know that the block is even original.
In 60 years there is a good possibility it was replaced. Farmers didn't like the added expense of antifreeze , so they simply pulled the water drain plug. I have seen many cracked blocks as a result of that practise and replaced many over the years. Unless you got the tractor from the original owner you never really know the history. Another common fix for a tractor that jumps out of gear was to replace the whole rear end assemble with another, that then gives you a new serial # tag. A lot of these old Farmalls are "Johnny Cash Tractors".
Mark -- Michigan
03-08-2004 21:33:48
Bret -- For what it's worth. The chassis and engine serial numbers match on my 1944 Farmall H. Both are in the 155xxx range. Every casting code on the tractor has a February 1944 pour date.
My compliments to Guy Fay on another good book -- "The Hundred Series". Hope you sell a million of them, Guy. I have one.
Mark
Farmallkid
03-09-2004 12:12:56
 Re: Re: Engine # vs. Serial # in reply to Mark -- Michigan, 03-08-2004 21:33:48
Why xxx out your serial #? Not that big of a secret is it?
Mark -- Michigan
03-10-2004 17:19:41
 Re: Re: Re: Engine # vs. Serial # in reply to Farmallkid, 03-09-2004 12:12:56
Farmallkid - You are right, it isn't a secret. I just can't think of a good reason to put it on the internet.
Mark
Farmallkid
03-11-2004 06:13:58
 Re: Re: Re: Re: Engine # vs. Serial # in reply to Mark -- Michigan, 03-10-2004 17:19:41
Ok. There is a farmall registry thing on this forum you could put it there, maybe somone has the one that was built infront or behind it. No i haven,t put mine on yet but i will. Have a good one!
Guy Fay
03-08-2004 20:50:20
At the front of a Farmall H parts book, it will tell you the break-before the break the numbers matched,a fter they didn't.
Bill Smith
03-08-2004 20:05:12
I believe the situation is, the earlier H's had a tendency to match and the later ones had a tendency to not match on serial #'s. I think my 43 numbers match. If I was you, I would just take my engine block serial number and use that same number if having a new serial number plate made. It's unlikely that you will find any archival info that would indicate your actual number using engine number as a reference. Just my 2 cents.
