I need an engine!!
ChadS
03-10-2004 08:38:00
Hey guys, I am sorry for leaving a "wanted" post on the discussion forum, but I am looking for a 200 ci IH 4 cyl. it looks like a 6 cyl with 2 cyl cut off it. LOL, it does not have to run, but rebuildbable, and not cost a million dollars. it is for an air compressor. any leads on one in northern indiana would be great!
NO ADS HERE
03-11-2004 09:24:17
 Re: I need an engine!! in reply to ChadS, 03-10-2004 08:38:00
Do you think you are better that the rest of us?
Kim told you before not to put ad here but you still do it. Are you that stupid???
BunkumBen
03-10-2004 14:36:51
Chad, I sent you an email regarding a C-200 engine.
Jim in michigan
03-10-2004 11:22:48
Is that a Slant 4 like used in Scouts and such? If so it is a excellent engine and i think I still have a few here. I know there was one in the pile out back,,...Jim
Red Dave
03-10-2004 11:43:52
 Re: Re: I need an engine!! in reply to Jim in michigan, 03-10-2004 11:22:48
The slant 4's were 1/2 of either a 304 V8 or 345 V8.
I had a '65 Scout 80 with a slant-4 cylinder, 152 cu in engine. esentially a 304 with the left bank of cylinders missing. Later I had a '78 with the whole 304. Same thing was done with the 345, I believe.
You are right though, good engines, just about bullet prof.
Duner Wi
03-10-2004 19:37:59
 Re: Re: Re: I need an engine!! in reply to Red Dave, 03-10-2004 11:43:52
As I recall the big 4 was 196 cu. in. and 1/2 of a 392. I could be wrong.
Gramps544
03-10-2004 09:23:42
I assume you are meaning the 200 ci IH 4 cylinder produced in the late 60's early 70's? You do realise this is the best Engin IH ever produced. Look for someone parting out a I-544 gas or F-544.
chadS
03-10-2004 09:55:27
 Re: Re: I need an engine!! in reply to Gramps544, 03-10-2004 09:23:42
I was not aware of that, this one had blown a head gasket, and they left the thing blown up, and did not fix it. it sat for 3 years, and it rusted up 1-2. head is still good though. How many hp are these engines? Chad
Andy Martin
03-10-2004 17:05:27
 Re: Re: Re: I need an engine!! in reply to chadS, 03-10-2004 09:55:27
Just because the two cylinders are rusted up does not ruin the engine.
Get the pistons out and clean up the cylinders. You might be surprised how good shape they are in.
