F-12 shootting flames
FARMALL POWER
03-14-2004 17:12:52
I have a 37 F-12, it hasen't ran for 5 years but i got it going, it shoot flames out the stack a lot, i fiddled with the carb but that diden't help, any suggestions??
Farmall Power
Bill Smith
03-14-2004 19:48:58
 Re: F-12 shootting flames in reply to FARMALL POWER, 03-14-2004 17:12:52
First guess would be that you got an exhaust valve that is sticking. Second guess would be that one or more cylinders is missing for any number of reasons (stuck intake valve, plug fauling, no spark, ext.). I assume you put in new gas. 5 year old gas would likely be no good. Carb should be O.K. on adjustments if it ran good when last run. Post back if you don't figure it out.
Nebraska Cowman
03-14-2004 17:54:06
have you got some valves sticking?
Andy Martin
03-14-2004 17:17:24
If you mean a nice blue flame you can only see at night or dusk when under load, for an M that means it is adjusted well. I assume the same for F series.
