Direct start WD6??
scottAR
03-17-2004 17:29:33
A friend has a road grader built on what looks like a WD6 and the gas system is in a 25 year state of disrepair but the diesel runs good. Surely someone on this board has come up with a starter heavy enough to crank it on diesel or knows that it absolutely will not work. He says he can pull start it with a small pickup but if he kills it with the blade in the ground, he has to go get a big farm tractor to start it. Help if you can. Thanks, Scott
Haas
03-18-2004 08:04:10
 Re: Direct start WD6?? in reply to scottAR, 03-17-2004 17:29:33
The compression ratio on the gas start diesels is only 15 or 16 to one on the diesel side. This is not enough to do a direct start with any kind of dependablity at all. For that you need 20 to 1 compression or more. For the lower compression, some kind of assistance is needed, such as extended pulling, ether, or glow plugs. Not a good idea to use ether on these, but they can be started that way. I doubt you could ever get a strong enough starter to crank them directly from a battery without the ether.
jed
03-18-2004 05:47:42
You could probably take the starter to a repair shop and asked them to convert it with a 50% drive reducer. I think that is what they call it. With that and a high CC marine battery, it should start.
I had an MD and it was the same way. It would turn over on diesel, but just wouldn't light up.
