Hydraulic Lift problems
David Green
03-27-2004 18:31:28
I have a 1951 Super A Farmall and the lift will not move. I never had this problem until today it worked fine. I pulled the pump off and everything looks good. I can see some of the hydraulic oil moving around in the Touch controll system but the lifts will not move at all. Thanks for your help.
David Green
03-28-2004 11:42:31
 Re: Hydraulic Lift problems in reply to David Green, 03-27-2004 18:31:28
That was exactly the problem. I remover the set screw and there was little to no oil coming out of the hole with the motor running. So i took a air hose and blew it out and the dam was released. hehehehehe. Thanks for your help again.
Jim Becker
03-27-2004 20:27:41
Probably a plugged orifice.
Look at the head on the back side of the hydraulic system. You should find a pipe plug screwed into it. take the plug out and you should find the orifice behind it. Don't remembe is the orifice is screwed in or what, but it probably unscrews.
You will have to pull the battery to get at it.
