Farmall Super A wiring Diagram?
Jarrett
03-31-2004 14:29:21
Hi ya'll. I've got a super A that needs major help with the wiring. Someone...NOT ME...striped all the wiring off, and I've got no idea how to put it back. Any help. I've searched this site, and found a wiring diagram from here but I'm not sure if this is the same as the super A. Any help Please!!! It's time to get in the field!!!
Jarrett
04-02-2004 16:37:27
 Re: Farmall Super A wiring Diagram? in reply to Jarrett, 03-31-2004 14:29:21
Ok guys...I got the wiring diagram and wired up the tractor JUST LIKE the diagram says. Started the thing up, and can't get any voltage out of the generator. Someone told me that I may not if I didn't polarize the regulator. I was told to do this that I needed to temporarily connect the A and F of the generator together. I did this with a screwdriver across the terminals, but no sparks or anything. I checked it with a voltmeter, and nothing. The thing is, I'm not sure that the generator is bad, because I can Ohm it out. I am very confused...Please HELP!
Thanks. Jarrett
Bob M
03-31-2004 15:04:31
That's the right diagram for your Super A!
little john
03-31-2004 14:52:37
Bob Melville's site that you visited before has a diagram for the "A". Maybe that would help. It is #14 on his index of wiring diagrams. Good luck!
