Says 340 utility but it is a backhoe
Ryan
03-31-2004 19:30:18
I have searched for hours and have found nothing on a 340 utility backhoe. Came close a few times but no luck. I just baught one and need to locate manuals. Plus would like feedback if anyone has ever had any experiance with one, good or bad.
MEK
04-01-2004 07:01:52
 Re: Says 340 utility but it is a backhoe in reply to Ryan, 03-31-2004 19:30:18
It's a 340 utility with a backhoe bolted on. You won't get a specific manual for the machine as a unit. Most likely, you'll get a manual for the tractor, but never find one for the hoe. Not a big deal, really. Backhoes are pretty simple and straightforward.
Geoff NY
04-01-2004 05:20:16
I have a 330 with a backhoe/loader made by Cone. I think around that time IHC was not producing their own hoes. I got in touch with the origanal manufacturer who was good enough to explain that at the time, they built the attachment as fill in work for IHC. Unfortunatly it still did not produce any manuals or other info. Good luck with it. Geoff
John Humphrey Morocco IN.
04-01-2004 04:50:35
Check out EBAY # 3806487349, this will give you the manual for the tractor part and leaves you with the task out finding manuals for the loader and the backhoe. Post the #`S on these and some one might help.
03-31-2004 22:31:44
I have a yellow International 340 with a trencher mounted on the back and a 2000 loader on the front. I was able to get the manuals from a Case/IH/Farmall dealer. Owners manual covers the Farmall 340 rowcrop, utility and the International 340 tractor.
w gatewood
03-31-2004 19:52:00
the tracotr is a industral 340 utilty and the loader and back hoe were added by ih
