400 Gas or Diesel?
David
04-07-2004 13:27:35
I'm looking to buy a 400. I have to sell a tractor yet but I'm putting my feelers out.
From what I am seeing, a 400 diesel can be had for not much more money than a gas model.
I am thinking about going ahead and getting the diesel. Does anyone know much about these 400 diesels.
This is an older diesel than I have ever dealt with.
Aaron
04-08-2004 07:14:33
 Re: 400 Gas or Diesel? in reply to David, 04-07-2004 13:27:35
Yes, the early farmall diesels were prone to head cracking. Parts can also be hard to find. I don't think you'd really have to worry about the head however if you don't overheat it. Also since diesels were less common than gas tractors at the time, I imagine the collectors value may be more.
MD Karl
04-07-2004 20:56:35
third party image
It is true that the start on gas diesels are more expensive to repair than the gas version. I completely rebuilt a 1951 MD and if I had to do it over again I would. I love that diesel engine. It is a very unique engine and often will turn heads. You won't get the horsepower out of the diesel that you would the gas. My tractor is however putting out around 50 hp, which in my opinion is pretty good. Proper care and operation of the diesels is important, especially warming up on gas as well as cooling the engine down by running on gas when you are ready to shut it down. I would not try and use one of these engines in a pulling tractor. I use mine for farm work and occasionaly show it. I really enjoy plowing with it and I have attached a photo of my MD with a 3-14" plow.
Ken Koch
04-08-2004 22:28:33
 Re: Re: 400 Gas or Diesel? in reply to MD Karl, 04-07-2004 20:56:35
MD Karl - I have a 1950 Farmall MD and a 3-14 Little Genius plow and plowed some mighty tough ground last fall. Blue clay! Had to brake the land wheel to keep from getting stuck BUT I never got that kind of smoke from my MD! Is my pump going bad or is it not set up right? Would like to hear any comments or answers. This is my first experience with a diesel. My dad had all gas Farmalls including a gas M on the farm but didn't get a diesel until I left home and that was a Farmall 856.
David
04-07-2004 21:10:27
I was under the understanding that the engine in the 400 diesel does not crank on gas like those in the MD tractors. Is that the case?
PS, nice looking tractor.
Aaron
04-08-2004 07:08:18
 Re: Re: Re: 400 Gas or Diesel? in reply to David, 04-07-2004 21:10:27
Yes, the 400's and 450's started on gas. Not until the 460, and 560 did they adopt glo-plug starting.
Geoff NY
04-07-2004 18:42:31
I have a 400-D and I love it, they are a bit more work and money than the gas jobs.. oh well. Of course some folks talk them down, but I grew up with an MD and we never had problems with it. To each his own.
big fred
04-07-2004 18:00:34
I pretty much grew up on one. Start on gas, switch to diesel. We never had any problems with ours. I'd love to have one, but with 5 acres of mostly forest, it's kinda hard to justify, even if I could locate one within 500 miles of here.
Dave
04-07-2004 16:40:40
I too had the want for a 400 Diesel ( I pull a 400 gas now). After doing a little research on the diesel version, I lost my enthusiam for one. From what I was told, they were a economical running tractor, stock hp was 1-2 less than a gas, diesel was prone to head cracking if engine got hot at all. You had to start the tractor on gas, let it warm up a little, then convert over to diesel. This told me that you would have the expensive pleasure of keeping both a gas and diesel system operational. Also was told that diesel parts were very hard and expensive to come by. Good luck.
