IH 574 transmission oil presseure sender
Glenn Mackenzie
04-08-2004 19:22:43
Hi there, does anyone know where I can find the transmission oil pressure sender on a 574? It sends a signal to the warning light when pressure is low. The original wire has been disconnected so I can't trace it back from the dash via the wiring diagram I have.
Thanks for your help,
Glenn
JB
04-08-2004 19:51:56
 Re: IH 574 transmission oil presseure sender in reply to Glenn Mackenzie, 04-08-2004 19:22:43
Hi, if I remember correctly it is under the seat and screws into the top of the transmission case.
Has a single wire with a spade connector.
JB
