IHC 1206 Farmall Hydraulics
kansascountry
04-09-2004 19:20:41
I have replaced the lift pump and relief valve on my 1206. I still have no pressure. I can barely lift the 3pt arms. I have put a loader on the tractor but it has trouble lifting the empty bucket. Anything else I could check?
Aces
04-10-2004 09:05:00
 Re: IHC 1206 Farmall Hydraulics in reply to kansascountry, 04-09-2004 19:20:41
The first think I would check would be the load valve under the seat, it is a big plug under the seat from the front. Should be a piston and ball and seat. The oring on the piston must be good the piston needs to be good, the seat tight and the ball good, the piston has a orifice and it needs to be clean sometimes the piston gets scored bad. If that is good then run a hose from a remote coupling to the dip stick tube, remove third link so you can see inside, start tractor, put that remote on so all the oil can go back into trany and then see if you see ant oil running down in the third link hole if so you most likly have a leak in the three pint lift. You do need the hose in the dip stick tube and the remote on without all the oil returns to the back and will look like leak.Repost with what you find.
kansascountry
04-12-2004 06:47:27
 Re: Re: IHC 1206 Farmall Hydraulics in reply to Aces, 04-10-2004 09:05:00
I checked both load valves they looked ok. I removed the 3rd member and operated the loader. I didn't notice anything out of the ordinary. When I did operate the remotes some oil flowed from the top of the rear end down. It looked normal??
Any other ideas?
