Block and head milling
Kent
04-11-2004 19:54:49
I have a 2544 and I am in the middle of an engine rebulild. I am taking it in to get it bored to clean it up and I thought of having the head and block milled to make sure they are true. The block has some pitting around a couple of the bores and maybe the milling would ensure a good seal. Anyone have any idea how much I can take off? Also what is the compression ratio?? Thanks Kent
Kent
04-12-2004 19:30:33
 Re: Block and head milling in reply to Kent, 04-11-2004 19:54:49
Thanks for the ideas men, that was what I was looking for. I want to keep it as simple as possible but I thought about finding the D-239? diesel when I found out a crank for the C-200 was $525 to $600. I was able to get mine reground to 20 under on the mains and 40 on the rods. The poor thing had STD bearings and I would guess it was ran out of oil after I spotted the brazing on the oil pan. Hugh, I hope all is well with you and your family. I have not been working on the 2544 much due to just starting on the new house. I did get it out of gear(3-gears at the same time) and cleaned out the tranny/rear/hydraulics. I am going to try and get someone to weld on the manifold and have it resurfaced. The only ones I have seen look like they have the exhaust outlet in the wrong spot. Any way thanks for the help. Kent
Kevin (FL)
04-12-2004 10:43:07
Kent,
I'm not familiar with that specific engine, but whenever decks or heads or milled, I ask the shop to do what we call a "skim cut"--that's only the amount needed to insure a flat surface. This process also makes for a good gasket seal too. Any cuts on either the deck (block) or the head will result in a slightly smaller combustion chamber and therefore, a little more compression. I don't know valve/piston clearance on that engine, but if you have any doubts about adequate clearance, this should be checked before running the engine. Usually this is not a problem though, but I wanted to mention it since I haven't built that particular engine before. If that block uses sleeves, you should also confirm how the sleeve height will work if the parts are milled. If so, you may have to take a cut on the sleeves too. The engine shop should be able to tell you that once they get all the parts on hand.
Hugh MacKay
04-12-2004 05:17:21
Kent: Still working on the 2544. You must have shifter figured out by now. Your were working on that when I last heard from you.
Did you ever consider looking for a 239 cubic inch diesel. 239 was the standard diesel for that tractor. Those 200 cubic inch gas engines weren't much even when new. 504 was the same spread, 153 gas or 188 diesel. The reputation on both these tractors were diesel was great and gas was an excuse. I'm not saying you should do it, rather just think about it. Thing to watch on the 239 diesel is where it came from. IH used that in British and American built tractors but the casting for mounting was a bit different. I think it was also used in some windrowers, and the casting may be different again.
Kent
04-11-2004 19:58:32
OOPS, forgot to add that it is the C-200 gasser.
