1949 M with disk brakes....
jamie
04-21-2004 18:22:30
Anyone know how to tell for sure if these are IH disks or the Lambert disks? I was wanting to replace the disks but it seems if they are the Lamberts that I have nowhere to turn. Help please...
Haas
04-22-2004 04:41:13
 Re: 1949 M with disk brakes.... in reply to jamie, 04-21-2004 18:22:30
Find a clutch/brake shop that does relining work. They can reline the Lambert Disks for you. The lambert disks have a different spline on them than the Super series disks. The Super series disks are flat with a narrow spline. The splines on the Lambert disks have an extended sleeve. When I redid mine, the IH dealer could still get the new disks for the Lamberts, but much more expensive than having them relined. After relining, the brakes work great. I needed a return spring that is internally mounted. Had a hard time finding that, as IH could not get. Also, the info about the mounting bolts provided by others here is correct. Three mounting bolts on the Lambert brakes.
Wardner
04-21-2004 19:30:53
The Lambert cast cover has three bolts. The later IH covers have five Bolts.
Your discs can be relined. The metal parts resufaced in a lathe.
Rich
04-21-2004 19:41:27
 Re: Re: 1949 M with disk brakes.... in reply to Wardner, 04-21-2004 19:30:53
Parts are available through Case IH dealers for both style brakes.
