Order Farmall Cub Parts Online
Cub A rear weights different??
Kevin (FL)
04-26-2004 04:58:01
Is there any weight or size difference between Cub & A rear weights? In other words are they identical and interchangable?
Haas
04-26-2004 05:37:17
 Re: Cub A rear weights different?? in reply to Kevin (FL), 04-26-2004 04:58:01
I have seen Cubs that have A weights on them. So they will work. I don't think the A weights look like they belong on a Cub though.
copper
04-26-2004 05:34:55
The bolt right up. I took my dads farmall A weights and have them mounted to my 1948 farmall cub. They weight more then my Cub weights do but they will bolt right up no problems.
copper
Kevin (FL)
04-26-2004 05:38:39
 Re: Re: Cub A rear weights different?? in reply to copper, 04-26-2004 05:34:55
Thanks for the quick replies--you fellas must be in the eastern or central time zone--or else you're up pretty early...
Red Dave
04-26-2004 05:21:28
They are not identical. Not sure if they are interchangable. They both mount with 4 bolts, you would have to measure the bolt patterns to see if they are interchangable.
