Super C still smokes
Dave_Id
04-26-2004 15:18:11
I posted the other day about the Super C running too rich... I think I have that taken care of. Replaced the plugs, it appears that two of my newer Champions plugs weren't firing right... it ran real good at idle, but not at full throttle. I also set the valve lash, retorqued the head and manifold... Now it smokes blue every now and then, then clears up.. Somebody thought last year I had a broken ring.... Any ideas????
PeteNY
04-26-2004 18:49:10
 Re: Super C still smokes in reply to Dave_Id, 04-26-2004 15:18:11
Id, we rebuilt ours over a year ago, but ither than a couple of pulls, and some puttering, she really hasn't worked much...still smokes a little when we start it. Pete
Farmer Bob
04-26-2004 18:35:47
Dave, Was this engine overhauled? Sometimes it takes a while for the rings to seat. If it has only seen light duty since the rebuild, I'd say as long as the blue smoke clears up, it's a ring or rings that haven't yet found the sweet spot.
Dave_Id
04-26-2004 19:15:32
 Re: Re: Super C still smokes in reply to Farmer Bob, 04-26-2004 18:35:47
Bob.. this machine has sat for the better part of 50 years.. Maybe only a couple hundred hours on it.. total.. That was why I thought maybe a broken ring. The original tires are just like new with just minor checking. I only put this back into service two years ago, and the toughest work it has seen is raking my driveway with the rock rake. It is a possibility that it isn't fully broken in...
