Joining discussion group
D.C. Arnold
05-04-2004 03:47:47
Just trying to get on the system. I have enjoyed and learned so much from this group in the past few years.
Previously I have tried to post without success.
Thanks to all for your wisdom and sharing.
I have a Super C and 340 Utility.
horselover
05-04-2004 09:16:30
 Re: Joining discussion group in reply to D.C. Arnold, 05-04-2004 03:47:47
i have a model m tractor and the piston rings are stuck i have freed them in three cylindes but number one is stil stuck do you have any sugestions also it is not a super m so is the engine the same bore and stroke as model h
26Red
05-04-2004 13:08:21
 Re: Re: Joining discussion group in reply to horselover, 05-04-2004 09:16:30
You make have pull the engine and drop the crankshaft and pound the piston out with a sledge hammer and block of wood.
Lots of labor but works every time.
TDK- reply to horselover!
05-04-2004 12:57:27
Type in "stuck piston" . Plenty of threads on the subject. The M has a 3 7/8 bore X 5 1/4 stroke, not even close to H, which is 3 3/8 X 4 1/4 .
49 Cubber!
05-04-2004 12:54:20
Keep working with it and soaking it.SUper M has 4" bore,M 3 7/8 bore and H has 3 3/8 bore.Completely different from the Super M.
Al Kolano
05-04-2004 06:00:00
Does any body know the shifting pattern for a IH 330 Utility?
Al Kolano
05-04-2004 06:24:41
 Re: Re: Joining discussion group in reply to Al Kolano, 05-04-2004 06:00:00
This is my first tractor so I have acouple other another stupid questions. There is a lever for high & low range. Is the shifting patern the same? And is there a neutral postion?
D.C. Arnold
05-04-2004 06:13:49
Al:
Don't know about 330 but 340U is what I call a double H.
Left Up=Reverse
Left Down=First
Center Up=Second
Center Down=Third
Right Up=Fourth
Right Down=Fifth/Road Gear.
Good Luck.
Jimmy King
05-04-2004 06:09:37
Top left Rev, bottom left 1st, middle row top 2nd, bottom 3rd, right top 4th, bottom 5th
faber
05-04-2004 04:18:21
You're now a pro.
Nebraska Cowman
05-04-2004 04:11:30
you're doing fine, see how easy it is!
