Mower Pitman Arm
Doug Kieta
05-07-2004 20:14:57
I am about to begin the restoration of an IH sickle bar mower for my Super A. The pitman arm is broken. I have both halves so can make a new one if necessary. Does anyone know if these are readily available already made? Anybody know what wood was used for the originals?
Thanks for any help offered.
D.C. Arnold
05-08-2004 07:11:40
 Re: Mower Pitman Arm in reply to Doug Kieta, 05-07-2004 20:14:57
Tractor Supply carries some.
Scott
05-07-2004 20:47:10
Try your local CNH dealer they should be able to order one for you. I think they are made from hickory same as a axe handle.
Doug
05-07-2004 21:26:22
 Re: Re: Mower Pitman Arm in reply to Scott, 05-07-2004 20:47:10
Try sickleservice.com. Probably has the one you need for about $12. Can get a generic blank for the same. I believe these are made from pecan wood. I bet any good hard wood would work.
