transmission oil farmall 560
Klein Rot
05-09-2004 07:20:31
Hi,
What type of transmission oil should i put in the transmission of an farmall 560 with hydraulic power steering.
Hugh MacKay
05-09-2004 14:01:14
 Re: transmission oil farmall 560 in reply to Klein Rot, 05-09-2004 07:20:31
Klein: I agree with Scott, stick with the Hytran. I bought oil from another supply once, they claimed was cross referenced with Hytran. within 6 months I bought pumps for 560 and 656. Problem with a lot of oils, they don't flow through the filters freely enough, thus starving the pump.
Scott
05-09-2004 09:51:51
Use Case IH hytran from a caseih dealer. If you change out all the fluid and filters you can use a high quailty trans hydraulic oil from some place like tractor supply but hytran is recommended.
