IHC H steering u joint?
Ralph
05-21-2004 07:23:30
Where can i get a steering u joint for a IHC H ? , and how much you think? Its the one under the hood closest to the steering wheel. Thanks
STEVE
05-21-2004 11:03:17
 Re: IHC H steering u joint? in reply to Ralph, 05-21-2004 07:23:30
Got one for my M at the case IH dealer. Seems like it was less than $20. Changed it just like a u-joint on a drive shaft. Use a big c clamp and a socket to push out the cups, then reverse to put them back. I never removed the shaft from the tractor
Dave S
05-21-2004 10:07:07
Take the old joint with you to Tractor Supply or simular store and see if you can find one close to the same size. I bought one from Steel Wheel Ranch but had to weld it on the upper shaft and drill a hole in the lower shaft to drive a spring pin through because it did not have a keyway. You will probably have to cut the old one off of the upper shaft with a torch or saw off if it is still original. I think cost between 25 & 30 dollars.
CNKS
05-21-2004 18:07:47
 Re: Re: IHC H steering u joint? in reply to Dave S, 05-21-2004 10:07:07
Usually all you have to do is replace the guts, the rest doesn't wear.
