int. 504 fluid level
steve
05-24-2004 21:11:30
am going to buy a int. 504 w/diesel+power steering. was looking at it the other day and wanted to check the hyd. fluid level in it. book that current owner has says the fluid level is checked by removing a plug on the right rear frame. cant find this plug anywhere. the book is not a factory one, could it be wrong? would appreciate any info.
Mike (MI)
05-25-2004 03:51:56
 Re: int. 504 fluid level in reply to steve, 05-24-2004 21:11:30
Yup, it's on the left side as you're sitting on the seat. The clutch lever is slightly in the way, as the plug is behind it.
Wardner
05-24-2004 21:40:37
The author is kinda like me. Can't tell my right from my left. Caused me some grief at Boot Camp.
The plug is on the left side. (I think)
steve
05-25-2004 07:22:22
 Re: Re: int. 504 fluid level in reply to Wardner, 05-24-2004 21:40:37
thanks for the help guys. might go pick up this machine this weekend if i can make arrangements for a trailer. mike you say that the clutch lever is kind of in the way, would that be the lever for pto engagement, or do you mean the actual clutch pedal?
