rusty fuel tank
Jeremy
05-28-2004 09:05:25
What is the best way to remove rust from a fuel tank. (H Farmall) I have been told that these fancy sealers will flake off after a short time. Is that true? if so, What could I do besides find another tank? Thanks in advance-Jeremy
Scott
05-28-2004 20:49:42
 Re: rusty fuel tank in reply to Jeremy, 05-28-2004 09:05:25
This may sound stupid but it works. I once worked on an M that had a lot of flaky rust in the tank. I could not get behind the baffle to clean it. I bought a small powerful ceramic magnet at the local hardware store and tied a gasoline resistant string to it. I then tied the other end to the gas cap. Every time I put gas in the tractor, I pull the magnet and clean it with compressed air. At first, the magnet was always loaded with rust. The tank has settled down and I have never had a problem with rust plugging the fuel system.
Rudi
05-28-2004 18:36:47
third party image
Jeremy:
If you want to make sure that there is no rust in your tank and that the tank is properly sealed, then do what I did for my Cub.
I took it down to a professional tank repair shop, radiator shops also repair gas tanks. Have them dip it, steam it or whatever procedure they use to neutralize the tank and remove the rust. Then have them seal the tank with the professional stuff - Red Coat or whatever they use.
It has been over a year, no more dirt except what comes with the gas these days, no chipping, no rust, no worries.
NDS
05-28-2004 16:58:01
If tank is badly rusted and you are not worried about color match and have good salvage yard around the best solution IMHO is to find a rust free tank and chunk the rusty one. Bough 100% rust free tank for M about year ago for $75. Some of the solutions for cleaning tanks such as putting nuts, rocks, etc. and rotating have the potential for setting off violent explosion. Just my 2 cents.
rustyfarmall
05-28-2004 14:33:15
Muriatic acid, use it full strength or you can dilute it 50% with water. Rinse with water several times, allow it to thoroughly dry, and you are good to go. You don't need the liner unless you have some pin holes that need sealed up.
Sean in Calgary
05-28-2004 13:43:46
Jeremy,
You are likely going to get a lot of suggestions so I will only speak to my experience. 2 years ago I was constantly fighting with a very rusty gas tank in my 350 Utility. Upon the recommendation of a number of folks on this board, I went to my local motorcycle shop and bought a product called 'Kreem'. This stuff came with an etching agent (I forget which acid but I think phosphoric) and neutralizer and the sealant to treat the tank. 2 years later, all is still just fine.
The only suggestions I would make would be to get 2 whole kits as there are really just enough chemicals in there to treat a motorcycle gas tank. The other advice is to use hot water when you add the acid to the tank. I am not making this part up. It evens says in the instructions to use hot water. I just used warm and really wish I had done what I was supposed to as it would have kick started the etching reaction a little better.
As I said, there are likely a thousand suggestions but I do know that Kreem worked very well for me.
Sean
Doc Holiday
05-29-2004 07:35:05
 Re: Re: rusty fuel tank in reply to Sean in Calgary, 05-28-2004 13:43:46
I have had excellent results from "Red Kote" tank sealer.
One thing you must do with any sealer is be sure to completely remove any moisture residue in the tank.
Most sealers specify using a solvent such as MEK (Methyl Ethyl Keytone sp?) to wash out the tank and completely remove all traces of moisture.
It is not nessisary to remove every bit of rust, as long as the loose rust is flushed out the sealer will cover any surface rust.
Be prepared to spend some time as it will take a couple of days to clean and let the tank properly air dry.
After the sealer is in place the best thing is leave the tank out in the sun for at least 2 or 3 days until all traces of the smell of the sealant is gone.
Its not a real easy job, it gets messy and you must follow the directions and you better have a helper. Be sure you get enough sealer too, for a M tank I usually pour in 2 quarts so I have plenty to slosh around and I don't have to worry about trying to get a small amount completely around the tank. After I'm done coating the tank I usually get about 1-1/2 quarts back out when I drain the excess. Drain the excess back into the can and seal the lid and it will keep for a long long time so you can use it on your next project.
Doc
