Jimmy King or Someone?
Allan
06-01-2004 08:56:23
third party image
On this 686 and it’s auxiliary battery. I can see holes in the floorboard for tie-down rods.
Am I to assume that I'm missing a battery cover or box here?
Thanks,
Allan
K.B.
06-01-2004 20:18:26
 Re: Jimmy King or Someone? in reply to Allan, 06-01-2004 08:56:23
Allan, from the looks of the parts book, there should be a base that bolts to to the platform, and a angle-iron hold-down at the top that attaches to the base with tie-down rods. On the 686 that we used to have, the previous owners removed the right step and replaced it with a battery box, and put both batteries down there. That really worked well, it was easy to get to, and got the batteries close to the starter, where they belong.
Allan
06-02-2004 03:48:30
 Re: Re: Jimmy King or Someone? in reply to K.B., 06-01-2004 20:18:26
Thanks KB,
That really helps. I knew there must have been something there originally.
Also, I don't think any of these old gals came with a right step, as far as I know anyway.
The mounting holes/bosses are drilled in the tranny housing, just no step. Maybe they were an option, dunno.
Thanks,
Allan
Hugh MacKay
06-02-2004 02:54:08
KB: That is exactly where I had the batteries on my 656, below floor board level and on each side of starter. I don't think I had 4' of battery cable in total. I initially put the batteries down there so I could use larger batteries. I also installed a cab at same time and could see, that servicing the batteries would become a night mare, in the factory location.
Jimmy King
06-01-2004 10:55:59
Allan I am not that familar with a 686, from the other posts it sounds like a battery sets there. Proably it had a frame that set on top of the battery open in the center, with two rods bent on one end in L shape to hook in the holes you show and a wing nut screws on other end at the frame. I had a 544 gas only 1 battery it was under the steering wheel the frame was long gone, but I would guess it had one when it was new. My 706 and 756 the batterys are long and narrow. They set at front of platform on each side the main body, this is what they have to hold them down.
Allan
06-01-2004 16:15:07
 Re: Re: Jimmy King or Someone? in reply to Jimmy King, 06-01-2004 10:55:59
Jimmy,
Yes, my 766 and 966 had those side mounted batteries as well; I kinda liked that neat look.
I've just never been around one of these "open air" 86 series before and know of no one around here who has one (Gotta have the cabs, ya know).
Thanks for the effort tho,
Allan
Jimmy King
06-01-2004 10:59:13
The battery cables would have rubber boots on them at the clamps
rustyfarmall
06-01-2004 09:37:30
Question number two, is that even the correct location for the battery?
Allan
06-01-2004 09:45:40
 Re: Re: Jimmy King or Someone? in reply to rustyfarmall, 06-01-2004 09:37:30
Hi Rusty,
Yep, they (my Red Mechanics) tell me that this model came from the factory with that extra battery setting back there.
I can't imagine it shipping without a cover tho.
The two holes in the floorboard are "staggered" like a normal battery hold-down usually is; one on one corner and another katty-wamphus on the other corner.
Thanks for the hollar,
Allan
