H motor froze
Tom
06-05-2004 07:00:26
I purchased a older Int H tractor. The motor is stuck. It has been sitting for a long time. I have the head and pan off. I have been putting pent oil and Marvel oil in the cyl. What is the best way to free it up. Will pulling it work?
Jed
06-07-2004 06:11:04
 Re: H motor froze in reply to Tom, 06-05-2004 07:00:26
Even if you get it turning you will still have to pull the pistons. Loosen the rod caps and drive the pistons out from the bottom.
El Toro
06-06-2004 06:40:16
Hi Robert, Pour transmission fluid over the pistons and let soak for a few days. Remove rod
cap and use a 2X2 oak or maple to drive out the pistons. Be careful not to damage the machined surface of the crankshaft. I had the same probem
with a Farmall A and I used wood to drive out the
pistons. Several wet sleeves came out with the pistons and I used a torch to heat the sleeves and the pistons were easily removed. I used the old rods with the new pistons and sleeve set. Good Luck, Hal
PS: Your H has dry sleeves and they may come out too.
RobertN
06-05-2004 18:12:28
There are a myriad of ideas of oils ect. Marvel, Kryoil might work. Amazingly, Coca Cola works well!
Put some lubricant/rust breaker in there. Get a block of wood that fits in the cylinder. Take a good sized sledge and whack it a few time, morning and eve, for a few days or a wekk. Will probably come loose.
CNKS
06-05-2004 12:23:27
I wouldn't pull it, if it doesn't break free you will probably bend or break something -- lot of opinions on this, everything from Marvel Mystery Oil to turpentine, to a big hammer, to attaching a big weight to the rear wheel and tugging on it every time you walk by, etc.
JON
06-05-2004 07:15:05
Pulling it will probly lossen the sleeves and all without the head . Are all the pistons stuck? if its just on or 2 sometimes you can un hook the rods from the crank and turn the motor over enough to get clearance and hit the pistons with a block of wood.There are some good posts in the previous 2 to 5 pages on how to un freeze a motor.
