M crankshaft
nebraska cowman
06-14-2004 03:15:37
will M crankshaft #45571DC work in a super M for casting number 45571DD ?
El Toro
06-15-2004 04:57:20
 Re: M crankshaft in reply to nebraska cowman, 06-14-2004 03:15:37
I read your question wrong, the M bearings and shaft will fit. Hal
Dave W V
06-14-2004 19:42:52
Cowman Randy is right,just use bearings for M
engine 501 to 278049 with DC crank.
El Toro
06-14-2004 19:25:22
The main bearing journals on the Super M crankshaft is .060" greater in diameter than the M. The rod journal is .050" larger than the M.
I still believe you'll have to use the Super M
bearings. These inserts have to be thinner in thickness since the rods are the same for both tractors. If you have the M engine disassembled
put the Super M crank in for a dry fit with its old inserts. I would do this before ordering parts. Good Luck, Hal
randy hall
06-14-2004 12:28:18
yes you just have to use the bearings for a straight m
El Toro
06-14-2004 12:00:29
According to the IH dealer in our area the Farmall M and Super M use the same connecting rods. The rod journal on the Super M is 2.5475-2.5485" and on the M it is 2.4975-2.4985". The mains on the M are 2.7475-2.7485". I thought the
bearings in the Super M may have been wider in width, but if the rods are same number, that isn't true. It should fit using the Super M bearings. The stroke is 5.25" on both tractors.
I was also concerned about the height of the pistons at full travel, but this looks to be alright. Good Luck Hal
El Toro
06-14-2004 07:24:19
Hi, My manual has the main journal at 2.808 inches for the Super M crankshaft. Do you have any
measurements for the M shaft? The cid for the M
is 248 and the Super M is 264. Hope this is some help. Hal
