Brocken F-20 even worse then I thought
Eric
06-14-2004 20:33:37
today i took the old 20 all apart most of the guys on ere should know what one im talkin about well it worse then i thought i have 2 broken pistons 2 broken sleeves 1 bent rod and cap not good i think im gona redo iyt all everything i've got it this far and i myswell make it worth it im gona put a engine kit in it i know some said they had parts if there new and cheeper then my local delership i might be intrested let me know of what you think on the whole deal Eric
nebraska cowman
06-15-2004 02:43:52
 Re: Brocken F-20 even worse then I thought in reply to Eric, 06-14-2004 20:33:37
Unless your pockets are just running over with money you can put used parts in it.
Eric
06-15-2004 15:50:23
 Re: Re: Brocken F-20 even worse then I thought in reply to nebraska cowman, 06-15-2004 02:43:52
Well im not exactly the richest guy around im only 14 but if i put used in it i dont wan tear it back apart i mean dont get me wrong its fun and all but i would like her to stay in one peace if something did go wrong again could be worse "Cracked Block" i think for the broken parts this time and the way it sounded im lucky thats all that is broke Eric
Dick Davis
06-16-2004 01:36:42
 Re: Re: Re: Brocken F-20 even worse then I thought in reply to Eric, 06-15-2004 15:50:23
Eric, I may have missed an intervening post from your first report, but have you determined what happened? If you've all ready explaind that OK. but if you are putting more new parts in the same way you did last time and hoping for different results, I would recommend stopping and reevaluating my plan. Any parts supplier or mechanic involved willing to help with replacements? My nickel Dick Davis
