Front weight on 460
Dave in WI
07-04-2004 21:26:31
What is the best way to add weight to the front of a 460? Were there wheel weights that fit the pressed steel wheels? Seems like I have seen bolster weights but don't how heavy they are. Was there suite case weight brackets fitted to these tractors. I plow a little ground with a 3 bottom 2 point (311) and it needs a little weight up front. Grand kids and I drive it in a local parade so want it to look nice. Thanks Everyone.
Jim
07-05-2004 05:19:27
 Re: Front weight on 460 in reply to Dave in WI, 07-04-2004 21:26:31
You can also take the bookcase weight bracker off of later tractor and bolt onto the front then use the weights - i took one off of a 706 and bolted right on.
scotc
07-05-2004 18:52:35
 Re: Re: Front weight on 460 in reply to Jim, 07-05-2004 05:19:27
I think all the weight boxes will fit any tractor, width might be a little different but mounts the same. Box off the 786 is on the cih 4240 after we stole the one from the 806 off of it for the 1566.
Will Sick
07-04-2004 22:33:17
They made bolster weights, Front weights that fit in a bracket that bolts on the front, and front wheel weights that fasten with four bolts.
