H liners
Dale L.
07-10-2004 09:56:43
I just ordered sleeves and pistons from my local parts man [National Bushing] they should be coming any day.According to most manuals all I have to do is apply lite oil and press or drive them in. My brother in law says I might need to take it to a machine shop to fit the sleeves. He knows alot more about it than I do. Does anybody have any expereance or advice on this procedure it would be greatly appreciated. P.S. I forgot to mention I'm working on a 1946 Farmall H
Wayne Swenson
07-10-2004 21:46:27
 Re: H liners in reply to Dale L., 07-10-2004 09:56:43
Be sure the groove in the top of the engine block is clean so the liner will not protrude too far and cause a head gasket failure.
Set the liner up-side down in the groove and see if it fits correctly.
As the other post explained, wrap the sleeve in newspaper and then freeze it overnight. The paper helps keep it cool while transporting from the freezer to the tractor.
Have a large hammer and a block of oak or other hard wood to persuade the liner to fit in place.
Do not strike the sleeve directly with the hammer. Don't get any wood slivers under the sleeve lip.
Have all the tools & supplies ready before getting the first sleeve out of the freezer; you do not have much time before the sleeve warms up and refuses to slide in place.
BIG JOHN
07-10-2004 18:21:20
Put them in the Freezer over night and then directly into the block using very light oil to lubricate them. Freezing them will shrink them every so slightly. Just enough to help them go in.
