Hand cranking a H
JimBub
07-13-2004 16:14:05
Hi guys, I got me a crank for the ol H and am missing the pin that goes thru the shaft on the front of tractor. I think a roll pin would work if anyone knows the dimensions would appreciate.
Roge WI
07-13-2004 19:57:35
 Re: Hand cranking a H in reply to JimBub, 07-13-2004 16:14:05
I just replaced the pin on the H I am working on now. Someone had sheared the pin off and had been using a vise-grip or pipe wrench to turn it. They had worn a groove around the shaft so I couldn't even find where the pin was. Finally used a punch in several places until I found a spot where the pin moved. As the others said, I just used a bolt (cut off the head and threads leaving about a 1/4 inch on each side) to replace the pin as a standard bolt fits tight in the hole. Roger
nebraska cowman
07-13-2004 17:45:11
i generaly make them out of an old bolt. just find one long enough so you can cut the threads and the head off.
TomH
07-13-2004 17:22:05
If you look at where the crank goes you'll see. The pin should stick out a little over 1/4 inch on each side, but more won't hurt.
Be careful cranking it, that's a good way to break an arm or rip off your thumb.
Jimbub
07-13-2004 19:00:29
 Re: Re: Hand cranking a H in reply to TomH, 07-13-2004 17:22:05
Thanks, I just plan on using the crank to adjust valves. But I know of people breaking thumbs and such. Any safety precautions from people experienced in starting tractors this way advice is welcome.
haymeadow52
07-13-2004 21:27:14
 Re: Re: Re: Hand cranking a H in reply to Jimbub, 07-13-2004 19:00:29
always make sure the transmission is in neutral and the brakes are locked.
dig
07-13-2004 19:11:01
1. Never, ever, EVER wrap your thumb around the crank handle. It's a real good way to get it torn off when the engine kicks back.
2. Always pull UP, never push down on the handle when cranking.
3> Be ready to let go of the crank at any instant.
