Oil Question
Andy
07-24-2004 11:38:49
What type of oil should I run in my 1945 Farmall A. I have been told all types 30W 10W - 30 15W - 40 what one is right? Also what brand of oil should I use? Thank you
Gene
07-24-2004 17:06:51
 Re: Oil Question in reply to Andy, 07-24-2004 11:38:49
I would start out with 20W30 and see if the tractor uses/looses oil. If the tractor uses oil switch up to straight 30W.
Brand of oil - your choice. I buy motor oil, gear, and hydraulic oil in 2 1/2 gallon containers from the local farmers supply.
The cheapest name brand oil, priced by the quart, is from the dollar stores.
nebraska cowman
07-24-2004 16:55:41
I tell people to just use whatever they run in their car. todays oils are made much better than what was available 50 years ago.
Hugh MacKay
07-24-2004 18:13:59
 Re: Re: Oil Question in reply to nebraska cowman, 07-24-2004 16:55:41
Cowman: And that is good advice, no point in having two types of oil around. With two oils, sooner or later someone uses the wrong one.
