Loose front end
Bartley Bass
07-26-2004 23:51:00
Is there a way I can tighten up the front end of my M farmall? It has a narrow front end. Its real loose. Any ideas?
Aces
07-27-2004 04:57:45
 Re: Loose front end in reply to Bartley Bass, 07-26-2004 23:51:00
Bartley Could be 3 - 4 different things bad bearing on front of werm shaft the werm gear warn bad or loose on the bolster fhaft bad bushings on the bolster shaft could be u joint under the hood could be all of the above.
