ideas for 656 loose steering arm
smirkey
07-27-2004 08:03:46
on my 656 hydro the lh steering arm is loose and i changed the key, also new tie rod ends. all this has helped stopped the wiggle a bit but still loose at the cast arm to spindle connection.i'm afraid it will wear the keyway worse. any ideas to fix this, is this a common problem w ih wide front ends?
Aces
07-27-2004 08:29:16
 Re: ideas for 656 loose steering arm in reply to smirkey, 07-27-2004 08:03:46
Smirkey on some of those arms I sawed through the arm where the bolt goes through so it can draw up tighter use a grade 8 screw if it does not have one in it.
smirkey
07-27-2004 08:35:07
 Re: Re: ideas for 656 loose steering arm in reply to Aces, 07-27-2004 08:29:16
thanks, my brother thought that that might work, but i thought it might weaken the casting too much. i guess a saws-all with a metal blade will cut it?
