Farmall H puller tranny problem
ChadS
08-02-2004 09:45:42
Hello fellas! I got a problem with my Farmall H puller. I keep eating up 4th gear top slider, it has a bad habit of popping out of 4th when I pull, usually when It lugs a bit, POP, nuetral!! I put a lock on the shifter lever to hold it in place,, worked well for years, now,, it pops out internally, but, the shifter does not move when it does it. Now, it pops in and out of 4th, under a load, is there any way to reinforce the shifter linkage to where it will stay in gear, and prevent this from happening? replacing the gear set and shafts as we speak, help!! LOL ChadS
Jed
08-02-2004 12:14:12
 Re: Farmall H puller tranny problem in reply to ChadS, 08-02-2004 09:45:42
On H & M tractors that I have had, that pop out of gear like that, I found that the rail is slightly bent. I remove the belt pulley mechanism
and with a bar I pry on the rail. It dosen't take much. This usually ends the problem.
lee
08-02-2004 11:24:34
Replacing the gears and shafts is going to probably fix a lot of it as worn gears is probably where it started. You'll also have to replace all the worn parts in the shift rail mechanism. Anything that's worn from having that shift handle strapped down will need to be replaced. Replace the detent springs with new ones.
