What went wrong???
Dewa
08-08-2004 20:28:11
Thanks guys for the responses. I found the problem and it was a long bolt where a shorter one was suppose to be on the distributor. It was up against the gear in front. Works fine now. Maybe I'll sleep tonight knowing she's not stuck!! Thanks again, Dewa
El Toro
08-09-2004 11:16:49
 Re: What went wrong??? in reply to Dewa, 08-08-2004 20:28:11
Hi, I see you have found the problem so you can
forget the message that I sent earlier. Glad it wasn't anything serious. I'm glad you didn't decide to tow it. If you can not rotate it by hand, I wouldn't pull it. Serious damage can occur when this is used. Hal
Gene
08-09-2004 10:14:13
Thank you. I wish others would respond once they have found the solution to their problem(s).
