Looking for used 12.4 x 36 rear tires
Bears
08-10-2004 08:43:59
Fell into F20 and am lookig for tires to move it around with. I am locaed in Eastern Iowa. Would appreciate the help if anyone knows of a place.
Bobcat
08-10-2004 15:00:58
 Re: Looking for used 12.4 x 36 rear tires in reply to Bears, 08-10-2004 08:43:59
I have a set of 11.25-36"s on split rims. They are weathercracked but would be usable. Give me a E-mail. Not too far from you!
Randy in NE
08-10-2004 12:10:47
I bought a tire from Ben Fish Tire Co
(712) 258-0653 in Sioux City, IA about 3 years ago. It even matched my other rear tire. It was a 12.4 x 36. About $325 mounted. It was a hot humid day so the $25 they charged me to mount it was well worth it.
rustyfarmall
08-10-2004 11:34:50
There is an outfit located in Monroe, Iowa that would come the closest of anybody to having what you need. I can't remember their name right now, but they also run a towing operation, repair shop, and they have the NAPA franchise. Monroe is pretty small, you should be able to find the phone number.
jal-SD
08-10-2004 09:51:41
Good luck-here in east central SD, 11.2 & 12.4 X 36" tires are not to be found. Too many C & Super C Farmalls that use them, they are snatched up before they hit the ground. Might try looking for 13.6's. They are scarce, but not nearly as hard to find as 12.4's & should work OK an a 20. We put a set of 13.6's on our '29 CC Case & they look good. (My $0.02 worth. jal-SD)
