Trans case capacity
Randy SE-MN
08-12-2004 12:09:51
Can one of you expert gentleman provide me with the Gal/Qt. capacity for my "52 H transmission case? Had to change out the 2 PTO seals and I guess it"s time to change out the gear lube too. feels like winter is just around the corner here.
walter
08-12-2004 12:55:48
 Re: Trans case capacity in reply to Randy SE-MN, 08-12-2004 12:09:51
6 gallons there is a small plug to check the level just in front of the clutch pedal
Randy SE-MN
08-12-2004 13:11:30
 Re: Trans case capacity in reply to walter, 08-12-2004 12:55:48
Thanks alot Walter. I knew the specs for my "m"s" but don"t have a book for the H yet. Randy
