Tractor idenification help
J Allen
08-16-2004 06:02:59
I have a good neighbor that has recently past away and his wife would like to sell a tractor they have had for a long time. I am thinking of buying it, but I need some help on the specifics. My neighbor thinks the tractor is a 1960 model 36 hp. I went over and looked at it no marking on shell except for the IH on the front. Motor is a gas 4 cylinder, markings C 135, firing sequence 1,3,4,2 & other number 107064. Has three point, dual hydraulics, new tires, small dual rear tires, wide front end. Could anyone lead me in the right direction to find out more about this tractor. Thanks for your help.
Grant
08-17-2004 17:33:31
 Re: Tractor idenification help in reply to J Allen, 08-16-2004 06:02:59
I'd say you have a 340 utility. They were made from i think 1959-63. Also 36 hp sounds about right for a 340. Its very interesting that the tractor has duals. I hadn't heard or seen that before. Probably worth $2-3,000 with the options listed. Good tractor.
J Allen
08-17-2004 19:42:37
 Re: Tractor idenification help in reply to Grant, 08-17-2004 17:33:31
Thanks for all the help from everyone, I am going ahead and purchase the tractor.
M R de la Secoya
08-16-2004 18:55:17
I just bought a Farmall Model 350. The owner says it is a 1958, but he does not know for sure. He said that it is about a 45 HP. Does anyone know anything more about it?
little john
08-17-2004 03:12:36
 Re: Tractor idenification help in reply to M R de la Secoya, 08-16-2004 18:55:17
Guy Fay's Data Book shows the 350 was made in '56, '57, and '58. He doesn't give the horsepower but 45 hp at PTO is about what is shown for other models using that engine. 40 at the drawbar.
sammy the RED
08-16-2004 10:07:15
My book showes that the C-135 was used in the following machines:
330
340
T-5
T-340
91 Combine.
CNKS
08-16-2004 18:18:36
 Re: Tractor idenification help in reply to sammy the RED, 08-16-2004 10:07:15
Also 404.
little john
08-16-2004 11:34:35
Sammy the Red. What book is that you refer to?
Sounds very detailed. Thanks.
little john
08-16-2004 07:17:19
Guy Fay's data book shows the C135 engine was used in the International 330, produced in 1957 and 1958.
