steeringwheel height on a farmall m
paul hoover
08-17-2004 19:38:38
i am looking at purchasing a 194? farmall m or h but i need to know what the height of the steering wheel is so i can fit the baby in my garage for storage. i have heard that tha frames are the same between the h and the m. if that is so i have seen that the steering wheel height on an h is 74 1/4 inches. can anyone help. also i am looking for wheel weights for my father in laws 1948 m.
Haas
08-18-2004 17:52:45
 Re: steeringwheel height on a farmall m in reply to paul hoover, 08-17-2004 19:38:38
With the muffler removed, the M will just go in a 7 ft high door. You'll need at least 9 ft wide, although with the wheels in, it would go in 8 ft, but no comfort zone for clearance. As the others said if you are using a 7 ft high door, you need to be very careful not to get yourself pinned as you go in or out. You must lean way down. I've kept my MD inside a barn that has 7 ft high doors for several years. Just built a new metal building with 12x10 doors. Now I can go in sitting up straight without worry of getting caught somehow. Really nice!
CNKS
08-18-2004 17:41:02
Guy Fay's data book says 78.25 inches, as others said depends on tire size. This dimension was probably with 11(12.4)-38 tires.
Dr.EVIL
08-18-2004 09:16:34
Everything on the M is at least 50% to 100% bigger/heavier than the same part on the H. That's why the H outsold it for the first 10 years they were produced. Everyone thought the M was too Big!
KeithF
08-18-2004 05:01:19
My Super M with the muffler removed will just sneak under a standard 7 ft. garage door with the door up as far back as it will go. It's a tight fit and one needs to be very careful and not get pinned or knocked off the seat. I have 13.6 x 38 tires.
john d
08-17-2004 20:06:19
Paul, I just put a tape up to my '49 M, and while the light wasn't the best, it's at least 81" to the top of the steering wheel. Removing the wheel would gain a few inches, but the top of the throttle lever assembly is probably 78" or so. The H and M frames are the same (or nearly the same) length, but tire size will change the overall length and height somewhat; for that matter, so will tire pressure.
Don't overlook the width factor. I don't know what the overall width of an M is from axle tip to axle tip, but if the wheels are dished out and it has 13.6 tires on it, you're dealing with almost 8 feet of width; certainly well over 7 feet.
