Order Farmall Cub Parts Online
early 50's cub...too much oil pressure
Mark in KY
08-19-2004 21:48:35
Hope someone here can help me help my dad. He has an early 50's cub that he uses to cultivate his tobacco. When the engine's first started while cold, the oil pressure goes way too high, and oil begins to leak out of a small crack in the oil filter cap (which we keep meaning to replace). After running for a bit, the pressure backs off to normal and everything seems fine, no more leaks or anything else.
The relief valve has been checked, cleaned and finally even replaced (both piston and spring). It seemed the obvious culprit, but the problem remained exactly the same.
What about fuel leaking into the cylinder due to a stuck carb float, etc. while it's not running? Is it feasible that it could leak enough fuel down past the pistons into the crankcase, creating too much volume, which returns to normal after leaking a bit?
What else could cause this? Any theories are greatly appreciated. Any similar experiences are even better! Thanks in advance!
Mark in KY
08-23-2004 07:08:19
 is filter not filler cap.....etc. in reply to Mark in KY, 08-19-2004 21:48:35
Hi all....
Thanks for the replies so far. It is the FILTER cap that has a small crack. I'm pretty sure the pressure really is too high, because the gauge pegs out for a while after starting, then later falls back to the normal range. I guess it's possible the gauge is faulty, but it reads normal after the leaking stops.
Yeah, the gasket is being replaced with the filters. We've picked an independent mechanic's brain and a shop manager at our local IH dealer, and the relief valve was the only theory they had.
Thanks again, and I'll post anything I discover and/or try.
Mark
Gene
08-20-2004 22:32:46
 Re: early 50's cub...too much oil pressure in reply to Mark in KY, 08-19-2004 21:48:35
Mark: Is it the oil filler cap or the oil filter cap? Curiosity.
I actually read the query both ways. My thought is that if the oil filter cap were cracked and leaking when the engine was cold, when the oil warmed, the crack should open wider and more oil leak out. May be not strange things happen.
Buzzman72
08-20-2004 08:29:47
 Oil FILTER Cap or Oil FILLER Cap? in reply to Mark in KY, 08-19-2004 21:48:35
After reading the replies to your post, I'm confused. Your post says the crack is in the oil FILTER cap, which is attached by the bolt that passes thru the center of the oil filter. If that is truly the site of the leak, there are 3 things I'd look at, if it were me:
*the cap itself...if it's not fitting square on the filter housing, THAT'S definitely a problem. If it's the problem, don't play games; replace it.
*the oil filter housing gasket UNDER the cap...you ARE replacing that EVERY TIME you change the filter, aren't you? And making sure you get every trace of theold gasket removed?
*the sealing ring between the bolt in the filter housing cap and the cap itself...original was a copper crush-type seal ring, and those are MEANT to be changed every time you remove the cap.
If the problem IS the filler cap instead of the filter cap, these other folks pretty much have your problem covered.
Allan in NE
08-20-2004 08:29:17
Naw,
You don't have too much pressure; you just have an old fashioned oil leak at that cap.
Allan
captaink
08-20-2004 08:05:05
Volume of oil and pressure are only related when you don’t have enough oil and you stave the pump! The oil pump can move a limited amount of oil and the pressure is limited by the relief valve. If you are concerned about too much (?) oil pressure, check your gauge by using a gauge known to be accurate. Your gauge may be off and need to be replaced. Personally, I agree with Gene that since you have replaced the relief valve already, as long as the oil pressure is normal when it warms up you have nothing to worry about.
Gene
08-19-2004 22:22:07
The Cubs have an up draft carburator - so that's not the problem.
I suspect the cause of the oil leaking out of the crack in the oil filler cap is splash from moving internal engine parts. I get a bit of an oil leak out of the filler cap/dip stick on my Cub when the engine is cold. Quits shortly after starting the engine.
JB weld on the crack.
As long as the oil pressure is in the normal range when the engine is warmed up - I wouldn't worry about it.
John *.?-!.* cub owner
08-20-2004 08:05:00
 Re: early 50's cub...too much oil pressure in reply to Gene, 08-19-2004 22:22:07
Mark, is the wire mesh still installed in your filler cap?
