International 656 Slipping Hydro
K.W.
09-02-2004 14:25:35
I have a 656 Hydro that is slipping and getting worse it is better in low.How hard are these to overhaul and is it costly. Help!!!!
TimFL
09-02-2004 23:19:31
 Re: International 656 Slipping Hydro in reply to K.W., 09-02-2004 14:25:35
I dont remember exactly cause it has been about 15 yrs since our 656 was apart. It seems like I remember that there is some sort of shock compensating disk mounted off the flywheel. It is spring loaded and works on a friction basis and wears out over time. When it starts slipping, as mine is doing now, the tractor wont pull. Split the tractor and replace it if thats it. Of course it could be hydraulic as well. I dont have my service manual handy either but I know that I&T makes a pretty comprehensive manual as well the IH reprint is available. They explain the system tests.
hagan
09-02-2004 20:14:39
$6,000.00 is what the Case IH dealer told me to fix a hydro 70 and I found a guy who wanted to give me $8000 for it to put under a argur and it is still there. doesn't move 100 feet in a week
Aces
09-02-2004 20:04:33
KW you better flow rate it first could be foot dump valve could be the relief valve could be charge pump. So need to find some one that can flow rate it first.
Allan in NE
09-02-2004 16:11:26
KW,
It will run anywhere beteween $2500 and $5K depending where you get it repaired and whether you break it down or not.
I've got a guy here that says he can sometimes rebuild them for just under $2K if it is brought in and is already taken out of the tractor.
Allan
mman
09-02-2004 19:06:02
 Re: International 656 Slipping Hydro in reply to Allan in NE, 09-02-2004 16:11:26
Have your pressure check first. It may just be adjustment of the foot-n-inch valve or hydro lever.
