Hydrolics on a C?
terryj
09-16-2004 09:41:10
I called about a C I saw advertised. The guy said that it had hydrolics infront of the seat at least thats where he thought they were. I have seen Super C's I think with a 3 point hitch on them before though I could be wrong. Is there anyway that a C with the Hydrolics infront of the seat be fitted with a 3 point hitch? If there is I will go look at it. It is about 2 hours away so hate to go that far for nothing. I would like the 3 point hitch to put a blade on for snow plowing in the winter. Thanks Terry
Randy in NE
09-17-2004 06:09:53
 Re: Hydrolics on a C? in reply to terryj, 09-16-2004 09:41:10
Yes the C can have both the original rockshaft hydraulics and a three point. They tap into the system and install a priority type valve so that you can operate either/both of them.
one row
09-16-2004 10:09:57
Terry, Here are a couple of links that have 3 point conversion kits.Worksaver is good for light work and less expensive, but saginaw is a much better kit.Hope this helps.
One Row
Link
http://worksaver.com/
