1466 tech question.
the pink panthe
09-18-2004 17:01:50
i went and looked at a 1466 today. low side of the T/A out, but you knew that already.good rubber and a K-5 koyker loader. my only problem with the tractor is that when you start it up when it has set 4-5 hours it clatters a couple of seconds, and the noise seems to come from the left side of the engine only. seems in the area of the injecter pump. could a inj. be hanging?maybe the pump is bleeding back a little and starting up dry? i really like this tractor and i want to buy it, but before i do i would like some advice from you folks on what that noise might be.
thanks barry
p--c--y-1066
09-19-2004 06:01:25
 Re: 1466 tech question. in reply to the pink panther, 09-18-2004 17:01:50
timeing advance in injection pump, nothing to worry about
Allan in NE
09-19-2004 06:27:13
 Re: 1466 tech question. in reply to p--c--y-1066, 09-19-2004 06:01:25
Yep, that's exactly it.
I've seen those old horses come to the end of the field, you idle 'em back and run over to the pickup to grab a cup o coffee and you notice that the thing is settin' back there a blowin', a snortin' and rattlin' like a corn sheller.
It does shake you up a little the first time you hear it; darned good pump tho.
Another noise that will throw you for a loop is those planetary gears in the rear axles sometimes "ticking" if they don't have a load against 'em, like when you are idling down the road in road gear.
First time I heard that noise, I called the service guy out. Cost me a $100 service call just for him to explain it to me. :>)
Good one to ya,
Allan
Allan in NE
09-18-2004 22:11:44
Normal as rain. Run it.
Allan
MN Scott
09-18-2004 20:46:04
My 686 makes that sound on startup too, after its been sitting for awile. It has a similer bosch pump to the 1466. If it makes the noise only a few seconds I would'nt be conserned with it.
K.B.-826
09-18-2004 19:51:45
Pretty typical, especially if it's a cold day. If the noise only lasts a couple of seconds, I wouldn't worry about it. Start it again, and pay attention to the oil pressure guage. Does it smooth out as soon as it gets to full pressure? These pumps have a device for starting that sends max fuel to the engine at low oil pressure. Burning all that fuel in cold cylinders can make that noise.
