oil leak on an 39A
yooper
09-18-2004 19:04:08
I have a 39 A with a rebuilt motor, I noticed it has a small oil leak on the head gasket. can I just retorque or should I replace the gasket, also do I need some kind of coating or paint if I replace?? thanks for any help
Jeff In Ontario
09-18-2004 19:26:48
 Re: oil leak on an 39A in reply to yooper, 09-18-2004 19:04:08
Yooper, I think you will do yourself a favor if you put in a new head gasket from the beginning. At some point it will be needed anyhow, so this saves you some troubles later...
That's what i'd do anyhow.
Jeff
