H head gasket leaking oil?
john in Ct.
09-21-2004 19:49:05
Is it possible for a Farmall H head gasket to leak a little oil with none of the other problems associated with a head gasket leak? thanks!!
Chadd
09-22-2004 12:47:44
 Re: H head gasket leaking oil? in reply to john in Ct., 09-21-2004 19:49:05
Our W-6 and our M do the same exact thing. I don't know why, but they still run great. I doubt that you have much of anything to worry about.
MagMan
09-22-2004 04:53:28
Hi John, Make sure you dont have your oil to full that is a good way to get leakage . My super M had about a half gallon of gas going in to the oil causing it to be over full and it pressured out everywhere it could find. But other wise like steven said if there is no other problems dont worry about it to much. JON
Steven f/AZ
09-21-2004 20:46:38
Yep, my new rebuild seeps a little bit in a couple places. Put the head on by the book with sealer and 2 retorques after running it!
Don't worry about it, just makes the side of the engine a little messy....
