touch control valve on a 300U
Charlie M
10-05-2004 18:41:55
A few years ago I added a second valve to my 300U and it has never worked correctly. The valve for the 2 pt hitch works OK so I know its the valve. The lever doesn't seem to go into one position all the way most of the time and the result is it works slowly. It works most of the time in the other direction but this year it started to not always work correctly either. There is a feel for when the handle is engaged correctly for normal lifting and the feel isn't there. Can anyone give me an idea what to look for?
Ibby
10-06-2004 03:21:42
 Re: touch control valve on a 300U in reply to Charlie M, 10-05-2004 18:41:55
It sounds to me like you have a chunk of debris in the system. I've had quite a few problems with my 350U with pieces of worn o ring floating around in the hydraulic system. I'd take it apart, clean it, install new seals and o rings, clean BOTH filters and try it again. Good Luck!
