Axle size on H
Dan in Ore
10-10-2004 02:46:37
I thought the "H" had the same size axles as the F-12/14 (2-5/8"). I can"t get my "H" wheels to go on the axles on the F-14.
Were the "H" axles 2-1/2"?
Dan
George Willer
10-10-2004 06:45:47
 Re: Axle size on H in reply to Dan in Ore, 10-10-2004 02:46:37
I suggested in an earlier post that you would need to get the wheels from an M. Strange, but true... the axles on an F-12/14 are heavier than an H. I think Case SC wheels would also work for you.
George Willer
Dan in Ore
10-10-2004 07:54:42
 Re: Axle size on H in reply to George Willer, 10-10-2004 06:45:47
Should have listened earlier. I thouught I learned someplace that the H and F-12/14 were the same.
Thanks for the info.
Dan
Glenn F.
10-10-2004 07:04:38
I thimk SC Case axels are 2 5/8". Glenn F.
George Willer
10-10-2004 09:00:37
 Re: Axle size on H in reply to Glenn F., 10-10-2004 07:04:38
Right... same as F-12/14. The difference is that the SC only has one keyway. That shouldn't matter.
George Willer
randy hall
10-10-2004 05:46:53
yes h's axles are 2 1/2".
