Tractor backfires
Rick from N D
10-10-2004 20:11:42
I am working on a W-4 McCormick Deering tractor.
It backfires when I try to start the engine. What could be causing this problem? Any help would be appreciated. Thank you. Rick
Novel Idea Guy
10-11-2004 07:45:41
 Re: Tractor backfires in reply to Rick from N D, 10-10-2004 20:11:42
Timing is 180 degrees off. Guaranteed.
I'll bet you picked the wrong TDC on cylinder 1.
F-Dean
10-10-2004 20:25:48
Make sure you have the firing order going in the right direction - double check the rotation of the distributor. My W-30 will run and backfire a lot if the firing order is in the wrong direction!
Farmer Bob
10-10-2004 20:14:09
Timing off or firing order not right. Recheck the firing order (1342) first.
Rick from ND
10-10-2004 20:18:06
 Re: Tractor backfires in reply to Farmer Bob, 10-10-2004 20:14:09
Thank you, I will check it out. Rick
