1486 injector sleeves
davids
10-19-2004 18:12:54
Is there a sleeve in the head that seals the compression from the injector? I"ve got compression leaking past the injector. Or is the copper washer the only thing that seals it? Thanks, Davids
Chuck's Repair
10-19-2004 18:50:21
 Re: 1486 injector sleeves in reply to davids, 10-19-2004 18:12:54
There is a sleeve in the head made out of brass,but it seals coolant and not combustion.The copper washer is the only combustion sealer.Make sure there is no carbon build up at the sealing surface.It has to be clean to seal.
Redman
10-19-2004 18:46:25
their is a injector sleeve,but if it is out you should be leaking water.
