Does this sound like a good buy?
Brian in NY
11-04-2004 13:29:46
Stumbled across a IH 504 gas this afternoon for sale.
I don't know much about these tractors, but she sure looked pretty solid.
Has PS, 3pt hitch, loader. Not sure but didn't look like it had a TA. Maybe it did. Needs paint and rubber, appears to have had engine rebuild as everything under the hood is dull yellow.
The fella is asking $3500 or best offer....
1) good price?
2) What to look for on this model?
THanks a bunch....
Hugh MacKay
11-04-2004 17:36:45
 Re: Does this sound like a good buy? in reply to Brian in NY, 11-04-2004 13:29:46
Brian: The 504 gas tractor was one of the first IH tractors not to have a sleeved engine. Problem is, after 2 or 3 engine rebuilds, your looking for a new engine, rather than a piston and sleeve kit as was the case with the older ones.
I had a 504, came with a farm I bought. Vendor had just rebuilt the engine at about 1,200 hours. He advised me not to keep it long. I had planned on trading my 300 on a new 1066. After a day in the field using both 300 and 504 on a 3x16 trailer plow, the 504 got traded and 300 stayed. Remember also 504 was supposed to be 8-10 more hp than 300. No so on that day, my old 300 out lugged the 504 on the 3 bottom plow by a wide margin. My 300 by 1975, was on it's 4th set of pistons and sleeves and probably had about 16 to 18 M hours on it.
SCRUFFY
11-05-2004 03:04:19
 Re: Does this sound like a good buy? in reply to Hugh MacKay, 11-04-2004 17:36:45
HUGH - I"ve been told the engine in the 504 the same one thats in my 93 combines. Is that true? I didn"t realize it was unsleeved, like a cub.
Hugh MacKay
11-05-2004 11:35:49
 Re: Does this sound like a good buy? in reply to SCRUFFY, 11-05-2004 03:04:19
Scruffy: I'm not exactly sure what engine was in the 93 combine. Two possibilities C-135 or C153. Good chance the C-135 was used in the 91 combine. The age of the 93 would make it right for the C-153. It is probably on the block in cast letter and numbers
