H water jackket
Dale L
11-12-2004 14:58:24
I rebuilt an H and put in the coolent. There is water leaking around the "metal plate" on the water jacket. It lools like it seeping around the bolts. Has anyone else run into this problem? And what is the cure?
TDK
11-13-2004 19:47:25
 Re: H water jackket in reply to Dale L, 11-12-2004 14:58:24
They will sometimes seep around bolts. The bolts run into the water jacket. Use a good pipe sealant or RTV on them. Works for me.
Larry Martin
11-12-2004 15:36:22
Dale, if you did not replace the water jacket cover you are probably going to find it rusted out. Replacements are available on this site.
Albert Jones
11-20-2004 23:08:23
 Re: H water jackket in reply to Larry Martin, 11-12-2004 15:36:22
I hade the same problem with my M. took the plate off and full of pin holes. I brazed the holes up with brass. Now its holding just fine
