Will the F12 head work on an F14?
jonesy
11-16-2004 14:43:59
Does anyone know if the F12 and F14 head are the same? Thanks
Jim Becker
11-17-2004 19:18:58
 Re: Will the F12 head work on an F14? in reply to jonesy, 11-16-2004 14:43:59
I believe they interchange but the F-14 head was higher compression (part of the power increase).
The F-12 to F-14 conversion kits from IH included a new cylinder head.
Fawteen
11-16-2004 16:42:17
Yes, they are the same. There are slightly different versions having to do with the placement of the rocker arm supports and valve cover design, but as far as I know, they will all interchange.
John M
11-16-2004 15:24:30
My parts book is showing 2 different heads,other than the Wakesha,but only one head gasket so I assume they will swap.
Harley
11-16-2004 22:50:52
 Re: Will the F12 head work on an F14? in reply to John M, 11-16-2004 15:24:30
Just watched a show on RFD-TV and they said the 12 hp F-12 and the 14hp F-14 were basically the same tractor only the F-14 they turned the RPMs up a little to get the extra 2 hp out of it. Later, Harley
